Is my transformer powerful enough ?
Old 03-11-15, 06:26 AM
R
Question Is my transformer powerful enough ?
I have a Honeywell 40 vac transformer. Do you think it's powerful enough to handle the following loads?
4 Honeywell V8043E1012 zone valves
2 Honeywell THM5320R modules for wireless thermostats
1 Honeywell RTH9580WF smart thermostat
Thanks in advance
Old 03-11-15, 06:58 AM
Houston204's Avatar
Received 95 Upvotes on 88 Posts
I would use at least a 50VA transformer.
I have installed many zone systems with 4 dampers and installed 50VA transformers to power them.
Depending on your valve actuators, a 75 VA might be advisable. Most 75VA transformers have a built in circuit breaker.
Old 03-11-15, 03:28 PM
R
Thanks Houston204
I won't take any chances. I went ahead and got the 75 VA.
Old 03-11-15, 05:51 PM
Received 4,052 Upvotes on 3,635 Posts
Good choice. The transformer will also run much cooler too without it being maxed out.
