Heat Pump wiring help for Honeywell rth6500wf
Old 03-22-15, 03:49 PM
H
I'm having a difficult time getting this wiring right. Old thermostat is a Comfortmaker.
Connection at system
New thermostat connections
I think I have everything connected correctly but heat doesn't come on. There is a jumper from W1 to E on the old thermostat.
Old 03-22-15, 04:20 PM
H
Here is how I have the new thermostat wired
Without the W1 to E jumper. Is this needed? Jumper wire below.
R red R
Y yellow Y
C black C
O blue W/O/B
G green G
W1 white W2/Aux/E
Old 03-22-15, 05:31 PM
Received 1,204 Votes on 1,114 Posts
Welcome to the forums.
We're missing something.... you have a green for G at the thermostat but not at the system end.
You have two red wires at thermostat and one at system end.
You have an orange wire on O at the system end and a blue on O at the t'stat end.
Is your "system" the A/C compressor end ?
You need to show the wiring at the air handler inside.
Have you programmed your thermostat for heatpump operation with backup heat ?
Old 03-22-15, 05:42 PM
Programming menu settings
1 ---> 5
2 ---> 0
3 ---> 1
5 ---> 5
12 --> 0
Old 03-22-15, 05:59 PM
Houston204's Avatar
Received 17 Votes on 14 Posts
It looks like the new stat is correctly wired.
I agree with PJ, that control board picture is the heat pump outside not the air handler.
If you configure it as PJ has posted it should work.
Old 03-23-15, 05:57 AM
H
Thanks for the replies guys. I had the system settings wrong I had #1 set at 0. And yes, that control board pic was on the unit outside. I'll have to take a look at the unit in the garage when I get home from work to be sure everything is wired correctly, but I'm pretty sure it is now.
