Honeywell RTH9580 Wi-Fi...Where to buy replacement base
Old 04-05-15, 06:18 PM
C
I managed to bungle the install a bit and need a new base. I bought the thing off Amazon. I'm struggling to figure out where to get one.
Thanks in advance!
Old 04-05-15, 06:21 PM
Geochurchi's Avatar
Received 161 Upvotes on 147 Posts
Have you checked Ebay?what did you do the base?
http://www.ebay.com/itm/HONEYWELL-RT...item4d2fd7a424
Geo
Old 04-05-15, 06:36 PM
Received 4,049 Upvotes on 3,632 Posts
Welcome to the forums.
There were two listed on eBay for $65. A pretty expensive bungle.
Otherwise you could try contacting Honeywell direct for a replacement base.
Old 04-05-15, 06:42 PM
C
It's working as it should. I know a couple of contacts where the unit and base connect got destroyed. I put a bit too much on it trying to get it attached with the wires not completely out of the way. It was a stupid move.
I was on another thread (pasted below) and someone mentioned getting a new base the next day. Seems like they're more readily available than ebay? I saw the ones on ebay but was hoping for something quicker.
http://www.doityourself.com/forum/th...heat-call.html
Thanks.
Old 04-05-15, 06:45 PM
No..... you misread the thread. The guy received a replacement thermostat with a base. Since he previously had the same stat he only swapped the stat. He was told to also change the base that came with the new stat.
Contacting Honeywell direct is the only way I know of getting one quicker.
Old 04-05-15, 06:50 PM
Geochurchi's Avatar
Good luck getting anything from Honeywell.
Geo
C
Yep. I missed that part completely. My apologies.
I'll call honeywell...or suck it up and buy off ebay!
Thanks!
Old 04-06-15, 04:33 PM
Geochurchi's Avatar
Let us know how you make out with Honeywell.
Geo
Old 04-06-15, 06:36 PM
C
I called and got "Alex" at honeywell. After giving him a bunch of my info, which included my state...he asked if that was in the United States. Hmmmph.
He wants a picture of the front and the back of the base plate. After that, they'll determine if they can provide a replacement. They may not be able to regardless.
What the heck? It was a frustrating 5 minute phone call.
Since the unit appears to be working fine, I may just live with it...and keep an eye on ebay.
Old 04-10-15, 01:30 PM
Geochurchi's Avatar
How long have you had it? maybe you could contact the supplier at Amazon and tell the base was damaged when you received it,it's worth a shot.
Geo
