Thermostat wiring - C wire
Old 04-10-15, 03:44 PM
I would like to install a new thermostat in my house (wifi+touchscreen) and pretty much all of the models i'm looking at require a C wire. Taking the faceplate off my current thermostat, I have a red wire to RH, a jumper from RH to RC, a Y/yellow, W/white, and G/green wire (as pictured below). I also have a blue wire, which when I look at my control board, is not connected to anything as far as I can tell. I notice there is already a white wire connected to the connection labeled "COM 24v", but it does not run through the same bundle of wires that go to my thermostat. Is it safe to just connect the blue to the "COM" connection on the control board along with the existing white (not sure where the white one even goes, if anywhere)?
Old 04-10-15, 04:34 PM
B
Received 1 Upvote on 1 Post
The white is most likely the 24 volt common going to your ac condenser outside.
It's okay to connect the blue to common if it's not being used for anything.
Old 04-10-15, 04:55 PM
Great, that's what I figured. Thanks!
