Do I have a C wire?
Old 06-14-15, 11:20 AM
T
Do I have a C wire?
Have a Lux 1500 running a heat pump AC unit. Do I have a c wire? Wires to following terminals: G Y W RH O RC (RH & RC connected by short wire.)
I want to install the White-Rodgers 1F86U-42WF Emerson Sensi Wi-Fi Thermostat. I think that will require a C wire...
Old 06-14-15, 11:31 AM
Houston204's Avatar
Received 75 Upvotes on 68 Posts
Your old thermostat does not have a C terminal.
You may still have a C wire if you have an extra wire that is not connected.
It appears that you have 2 green wires. If this is the case you probably have and additional red and a white wire available.
Connect this extra wire to C at the furnace and the new stat if it is present.
Old 06-14-15, 12:31 PM
T
Thank you for your help!
If there are extra red and white wires, would they be tucked behind the the existing thermostat?
Old 06-14-15, 01:18 PM
Houston204's Avatar
Yes.
If you have 2 green wires red and white are probably tucked behind the stat.
Old 06-14-15, 02:58 PM
T
This is what I have. The beige(ish) -- upper left -- wire is the only one that is not being used...Name:  IMG_20150614_144737.jpg
Old 06-14-15, 03:45 PM
Houston204's Avatar
Looks like I was calling a blue wire green.
At least you have a wire to use for C at the stat and the furnace.
Old 06-14-15, 03:53 PM
T
So can I use that beige wire as the c wire?
Thanks again for your help!
Old 06-14-15, 04:00 PM
Houston204's Avatar
Yes, connect brown to C at the stat and at the furnace.
Remember to turn off power to the furnace when replacing the stat.
If you touch R to C it will pop a fuse or take out the transformer if a low voltage fuse isn't present.
This York board has a 5 amp fuse...
This Carrier has a 3 amp fuse...
