Help installing new thermostat please
Old 06-19-15, 10:21 PM
T
I have a york B1HP036A06A central heat pump and my old thermostat is a white rodgers 1F78-144 and my new thermostat is a ecobee3. My old thermostat had a red wire going to rc then jumped to rh, green wire going to g, yellow wire going to y then jumped to w and a orange wire going to O. I also have 8 wires in the wall
Old 06-19-15, 11:25 PM
Received 1,107 Votes on 1,027 Posts
Welcome to the forums.
We can give you a hand wiring the new stat.
You have a heatpump system with no electric backup coils..... correct ?
You'll need to check where your thermostat wiring connects at the air handler for a C terminal. You'll need to connect one of your spare wires to the C terminal.
Old 06-19-15, 11:47 PM
T
Im not sure with the electric backup how can i check and just to make sure so i can take a wire and hook up to c on the main board because yesterday i did that and it worked i set up the thermostat but was not able to get it to turn on the unit and the was a question also I didn't know when setting it up it had something to do with the reverse valve not sure exactly but when i get the tstat started again i can check
