Honeywell rth6580wf thermostat to system 2000 boiler
Old 10-18-15, 04:40 AM
Trying to hook up Honeywell thermostat rth6580wf to a system 2000 boiler. The current thermostat is an old Honeywell Mercury switch. There are 2 wires connected to the thermostat. The wires are very old. Was going to run new wires. Not sure where to hook up the wires to boiler for the new one. The directions say to you need a "C" wire to supply power to the new thermostat. Not sure where to hook it up at boiler.
Old 10-18-15, 05:34 AM
V
Received 2 Votes on 2 Posts
Don't you see where the "old" wires come down from the living quarters and enter the aquastat ?
Old 10-18-15, 09:09 AM
Yes I do. The terminals on the OLD thermostat don't have identifications on them.
Old 10-18-15, 02:13 PM
Houston204's Avatar
Received 34 Votes on 30 Posts
Many boilers are not labeled R, W, and C. They have T and T.
It is often necessary to connect an external transformer to Rc and C on the new thermostat. Connect thermostat R(h) and W to the two wires that connect to T and T at the boiler.
Old 10-18-15, 02:37 PM
Received 2,813 Votes on 2,545 Posts
Does your boiler use one of these controllers ? If so... which one.
Heat Monitor | Home Heating Monitor | Classic System Manager
