Honeywell prestige 2.0 EIM wiring
  #81
Old 06-04-16, 07:35 PM
Houston204's Avatar
Received 18 Votes on 15 Posts
Can I see a picture of those dip switches?
  #82
Old 06-07-16, 03:05 PM
R
Did you get the pic. of the dip switches ?
  #83
Old 06-07-16, 08:02 PM
Houston204's Avatar
No, I have not received any pics...
  #84
Old 06-09-16, 02:09 PM
R
Houston, I don't know if I attached the jpeg file correctly. not very computer savy.
  #85
Old 06-11-16, 06:31 AM
Houston204's Avatar
Your dip switches match the manual that I have. Do you have the manual that came with your furnace?
I have seen changes in the manual from one year to the next before.
  #86
Old 06-13-16, 02:56 AM
R
Thanks Houston, yes they match, I am thinking my whole problem is not enough return air. I have a central return 14 inch with a 14 x 25 grille. and a 6 inch with a 10x 10 grille. I am going to add another 12 inch return with a 14 x 14 grille. I will let you know after I install it.
  #87
Old 06-16-16, 05:26 PM
Houston204's Avatar
It may be time to call in some professional help to inspect your ductwork for leaks and check the charge.
