Where to connect C wire to?
I just bought an ecobee3 thermostat. My current thermostat is only using 4 wires, but it has an extra unused one (the green one that's wrapped around the cable). My question is where do I connect the green wire to to make it my C wire since I don't have 5 terminals inside my HVAC.
Here are a few pictures including a diagram: Imgur: The most awesome images on the Internet
The unit is 15 years old and I tried to reach out to the company but they switch away from HVAC and can't help.
Thanks in advance!
Thanks in advance!
Welcome to the forums.
Your pictures were spot on and made the job easy. In the picture below I labeled your C connection. It's the screw terminal where the two blue wires connect. You can connect your green stat wire there.
