Replacing Bryant thermostat with Honeywell 6350D
Old 12-08-15, 03:19 PM
G
Any assistance would be appreciated...
Old Bryant unit
W
O
G
R
C
Y
no blank terminals, wire on every terminal listed above.
New Honeywell
Y2
W2
G
W
Not Used
Y
R
RC
Old 12-08-15, 03:42 PM
Received 1,476 Votes on 1,364 Posts
Welcome to the forums.
What color is on which terminal ?
Since you were using the O terminal.... you should have a heat pump system.
Does it have backup electric coils ?
Old 12-08-15, 03:58 PM
G
Pic attached. Have no idea about back up coils... I guessing unit is 15 yrs old.
Old 12-08-15, 04:14 PM
Are you sure of that model number...... Honeywell 6250 ?
Old Bryant unit
W -----> white
O -----> orange
G -----> green
R -----> red
C -----> brown
Y -----> yellow
Old 12-08-15, 04:54 PM
G
No, it is a RTH6350D. I apologize, no glasses on.
Old 12-08-15, 05:45 PM
That's better.... one further problem.
Your list of terminals on the new stat do not match the online manual.
Old 12-10-15, 06:20 PM
G
Sorry for delay, been a long day.
Another set of markings under terminal for Heat Pump
L
Aux/E
G
O/B
Not Used
Y
R
RC
Old 12-10-15, 06:39 PM
Old Bryant unit-----> new stat
W -----> white ------ > Aux/E
O -----> orange ------> O/B
G -----> green --------> G
R -----> red -----------> R/Rc - should be a jumper in place.
C -----> brown --------> cap off - not needed
Y -----> yellow--------> Y
If you have a separate aux and a separate E..... you'll need to put a small jumper between them. If it's one terminal.... you're set.
The following are programming changes you need to make in advanced settings of thermostat. They'll be discussed in the installation booklet.
Function 1 ---- > 5
Function 2 ----> O
Function 3 ----> 1
Function 5 ----> 9
Function 6 ----> 9
Function 8 ----> 9
Old 12-16-15, 01:13 PM
G
Thanks for your assistance....
-GG
