Help installing a Honeywell RTH9580WF Thermostat
Old 12-19-15, 09:42 PM
R
Post Help installing a Honeywell RTH9580WF Thermostat
Hi, I just purchased a Honeywell RTH9580WF Thermostat and I need help installing it to my GMP100-4 REV B Furnace. The wiring on my original Thermostat is a bit different to what the new one uses.
Original Thermostat
Name:  Thermostat Connections.jpg
Furnace Wearing Diagram
Name:  GMP100-4 REV B.jpg
Name:  New Honeywell WIFI RTH9580WF.jpg
Please help!
Old 12-19-15, 09:55 PM
Received 928 Votes on 865 Posts
Welcome to the forums.
You are showing four wires between the stat and the furnace. You are going to need five wires as the stat requires a C connection. Are there any spares in the cable ?
Old 12-19-15, 10:32 PM
R
There is a spare cable that's not connected.
Old 12-19-15, 10:42 PM
red --------> R (leave jumper plug in place)
black ------> W-O/B
yellow ----> Y
green -----> G
???? ------> C (a screw into metal at the furnace)
Old 12-20-15, 07:19 AM
R
Ok thank you. I will be hooking it up today so ill post when its up and running :-)
Old 12-20-15, 12:16 PM
Houston204's Avatar
Received 17 Votes on 14 Posts
24 volt common is the blue pigtail wire sticking out of the furnace with many Goodman units.
