Go Back  DoItYourself.com Community Forums > Heating, Cooling, Air Conditioning, Ventilation and T-Stat Controls > Thermostatic Controls
Reload this Page >
Need help replacing old Bryant Thermostat with new Honeywell RTH7600, RET97
Old 12-21-15, 03:14 PM
Outside unit is a Bryant HP #663CJ036-A
Furnace is a Bryant 373LAV
Instructions read; if old tstat had Y1, W1 and W2 wires, stop & contact qualified contractor
I don't think it should be that difficult, but wanted to see if anyone had dealt with this before.
Can't seem to insert any images.
Old Bryant tstat wires vs. terminals
yellow - Y/Y2
white - W/W1
green - G
jumper? - Y1/W2** to L
orange - O/W2*
red - R
blue - C
black - S1 *does not have outside temp reading
tan - S2 *does not have outside temp reading
New Honeywell tstat terminals
C
G
Y
O/B
RC
R
AUX
E
L
Old 12-21-15, 03:31 PM
Houston204's Avatar
Received 17 Votes on 14 Posts
Are you sure Y1 is jumpers to W2 not W1?
Can you post a picture of these connections?
Old 12-21-15, 03:46 PM
Can't seem to get pics to load...
The jumper wire is connected on one terminal block to Y1/W2** , then connected on the other terminal block to L
Printed under the blocks is:
*O for HP, W2 for AC
**Y1 for 2 speed, W2 for
3 stage heat (Sw C off & D on)
Old 12-21-15, 04:00 PM
Old 12-21-15, 04:38 PM
Received 1,473 Votes on 1,361 Posts
If you're posting pics from a phone.... they're too large. http://www.doityourself.com/forum/el...-pictures.html
Old 12-21-15, 07:19 PM
Houston204's Avatar
Do you have a model number like TSTATCCPAC-01 on the old stat?
It is strange to work for a Carrier dealer for over 24 years and not know any Bryant numbers.
Old 12-21-15, 08:13 PM
Thanks PJmax for your instructions on using Photobucket...
Houston204 - model # below
Model # (or at least the only # I can find) 960-3003-00002 REV A
Any help is greatly appreciated...
Pic of old Bryant tstat wiring / terminal blocks
Pic of new Honeywell tstat terminal blocks
Old 12-21-15, 10:49 PM
I came back to edit my post. You have a single stage gas furnace and a heat pump. I don't believe the new stat you got will work for your system.
You have what is called a dual fuel setup. You'll most likely need a dual fuel kit. This is used to lockout the heat pump when the furnace is running. They cannot both be running at the same time.
Houston should know.
Name:  old tstat terminal2_zps0zswrso2.jpg
Old 12-22-15, 05:14 AM
Houston204's Avatar
The Honeywell VisionPro TH8320R or the TH8321R will support your dual fuel application.
(The retail models available at the hardware store will not. They start with R)
I would also get the Honeywell Redlink outdoor temperature sensor. It would unlock more options in your application.
Old 12-26-15, 01:14 PM
Follow up to replacing old tstat...
Looking at the wiring diagram for the Honeywell TH8321, I'm still a little confused on a couple of things.
old:
new:
I get Y, G, O, R & C, but where do I go with W & the jumper between O & L from the old tstat? What do I use for L, E & AUX on the new tstat?
Old 12-26-15, 05:15 PM
Houston204's Avatar
RC , R - Red
Y1 - Yellow
G - Green
O/B - Orange
Aux, E -White
C - Blue
The Redlink TH8321R is the modern model. The TH8321U is the obsolete version.
I would use the Honeywell wireless Redlink outdoor sensor.
Old 01-05-16, 04:52 AM
So that's a jumper between Aux & E, with the white wire running to one of the two terminals?
