Honeywell RTH9580 wi-fi troubeshooting
Received 0 Votes
trying to upgrade to a RTH9580 thermostat and cant get the furnace to start-no heat-my old thermostat had white,red,green and yellow wires-i had an extra black wire and used that as my C wire and hooked up to the common on the furnace and at the thermostat
My new rth9580 powers up and I can start the blower manually, but in the heat cycle nothing happens
Any suggestions would be appreciated..Thanks
If you have electric heat you must configure the new thermostat for electric heat.
The thermostat controls fan in heating.
If you have gas heat it can take 90 to 120 seconds before the blower would turn on.
Received 0 Votes
Thanks..I called Honeywell support and went through the wiring setup and setup of the thermostat for our furnace. Everything seemed fine..installed an older thermostat. Everything is working know. Honeywell suggested returning this thermostat and trying another
