Nest, dual zone trol-a-matic
Hi All,
Looking to upgrade to new thermostats in my home that was built in 91. Have a dual zone dampener system by Trol-a-Matic with two thermostats.
Currently have a Honeywell RTHL2310B in the basement wired as such:
In the upstairs there is an old round dial mechanical thermostat wired like this:
The trol-a-matic is wired this way:
My wife would like two nest thermostats installed. Is this possible?
Thanks!
Thanks!
Welcome to the forums.
I don't believe you can connect two nests to the Trolatemp board. I'm pretty sure you'd need to upgrade to something like the Honeywell HZ311 - three zone controller.
Is this a heat pump system and if yes.... is there back up electric heat ?
The HZ311 is not used for a heat pump.... you'd need a HZ322 instead.
