Replace heating thermostat
Received 0 Votes
Hi guys.
So, I've recently purchased a new property. It has a combo boiler, which provides hot water and the central heating. This seems to be working fine, however, the thermostat on the wall appears to be damaged.
It is a Sunvic thermostat, which I can tell from a marking on the inside. However, the LCD display is not working properly, so I cannot tell what temperature the heating is set at or anything... So, I was looking to replace the thermostat.
The thermostat is a wireless thermostat, and looking at the Sunvic site, it looks like it is probably the TLX 1010, as the wireless thermostat looks the same, and next to the boiler and controls, is a box similar to the receiver. Here's some pictures:
Am I right in thinking I can just purchase another of these, swap over the box in the wall (or keep it as a spare, can I pair the new thermostat with the old receiver) and then just put the new thermostat back on the wall?
Or, would I be better to swap to a different thermostat? Any given would be appreciated (as you can tell, not really knowledgable on this part).
All information gratefully received.
Many thanks,
David
Many thanks,
David
Received 0 Votes
Have you any examples of ones which would wire up in exactly the same way (i.e. for my thickness ease of use)? I would like a Nest style thermostat, but from what I seen, the nest isn't wireless, so won't be able to use that where the current thermostat is. The boiler and controls are in bedroom upstairs, so will be warmer than downstairs, where I would like the thermostat...
Cheers
Cheers
A Honeywell Redlink TH8110R thermostat with an EIM would be a good choice for a wireless low voltage application but that looks like a high voltage thermostat model number.
