Go Back  DoItYourself.com Community Forums > Heating, Cooling, Air Conditioning, Ventilation and T-Stat Controls > Thermostatic Controls
Reload this Page >
Wiring info to replace Weathertron BAY28X139 with Honeywell RTH6350D
Old 05-30-16, 10:48 AM
I'm trying to replace a Weathertron BAY28X139 with a Honeywell RTH6350D.
Weathertron has connections labelled:
R
T
O
G
Y
X2 jumpered to W & U
B
F
Honeywell has 2 identifications for each terminal:
Y2 - L
W2 - Aux/E
G - G
W - O/B
Not Used - Not Used
Y - Y
R - R
Rc - Rc
Documentation covers 3 ways of hooking up the Honeywell, none of which match.
Can anyone explain the correct way to hook up the Honeywell, or suggest a different replacement?
Thanks
Old 05-30-16, 11:54 AM
Received 255 Votes on 240 Posts
Welcome to the forums.
We need to know what color wires you have on which terminals.
A picture is ok. http://www.doityourself.com/forum/el...-pictures.html
The letters are not just matched between stats. Different stats assign different functions to different letters.
Old 05-31-16, 12:55 PM
Wiring photo
Note: - black had come adrift from F, so AUTO didn't work. Reconnected to F, and it AUTO worked.
Old 05-31-16, 08:33 PM
Houston204's Avatar
Received 10 Votes on 8 Posts
R = RC & R ( 24 volt power)
T = thermostat (Tape off this wire)
O = O/B (reversing valve to cool)
G = G (fan)
Y = Y (compressor)
X2 = Aux / E (heat strips)
B = C (tape off this 24vac common wire)
F = L (fault light) I would tape off this wire as well
F should not be able to control the fan. Could this have been a coincidence?
Remember to remove power to the indoor unit before replacement.
Old 05-31-16, 08:47 PM
I would have expected to see the black on X2.
Since you're in Md. ..... I'm sure your system has heat strips.
What may have happened is that heat and A/C was coming on at the same time.
