Go Back  DoItYourself.com Community Forums > Heating, Cooling, Air Conditioning, Ventilation and T-Stat Controls > Thermostatic Controls
Reload this Page >
Need Help replacement Thermostat White-Rodgers 1F82-54 with 1F95-1277
Old 12-08-16, 01:08 PM
B
I would like to replace my old White-Rodgers 1F82-54 thermostat with the brand new White-Rodgers 1F95-1277.
I have encountered a small problem in the connections.
The connectors of the new thermostat, are not the same to 100% with the old one.
Old Thermostat White-Rodgers 1F82-54
C
G
R
O/B
Y
W2
New Thermostat White-Rodgers 1F95-1277
W/E ---------- L
W2 ----------- O
G ------------ B
RH ------------ Y1
RC ------------ Y2
C
My question: how do I wire the wires on the new thermostat.
Thank you very much for your help.
Old 12-08-16, 01:53 PM
Black wire goes on C terminal
Red goes on RH and make sure its jumper to RC
W/E not used
Green wire goes on G
L not used
Orange goes to O Unless you have a Rheem or Ruud heat pump then it goes on B
White wire goes on Y1
Y2 not used
Thanks PJ
Old 12-08-16, 02:04 PM
Received 3,422 Upvotes on 3,068 Posts
The wire on G is green. Easier to see after I reposted the picture.
Old 12-09-16, 06:02 AM
B
Thank you guys for your help, I'll try it all tomorrow Saturday and get you back with the result.
Old 12-09-16, 06:46 AM
B
My heat pump is I.C.P
To summarize the good wiring is:
Black goes on C
Red goes on Rh+Rc
White goes on W/E
Green goes on G
Orange goes on O
Yellow goes on Y1
Old 12-09-16, 06:50 AM
B
Am I correct with this wired?
Old 12-09-16, 08:01 AM
Your wiring is ok but there may just be a Y and not Y1 on that stat.
Old 12-09-16, 08:44 AM
B
Hi PJmax,
I did not understand the meaning of:
(Your wiring is ok but there may just be a Y and not Y1 on that stat.)
Can you give me, more détails
Thanks a lots.
