Emerson Sensi UP500W installation issue
Old 01-09-17, 07:38 AM
Hello. I am looking for some ideas on why after I installed my new Emerson UP500W thermostat my AC will not cool. The fan kicks on and air flows but it is not cold air. The heat pump does kick in and puts out hot air. I called Sensi support and they confirm all my wires and setting are what they say they should be so they are a dead end for my issue. I have a Lenox 14HPX-048-230 single heat pump system. Attached is a picture of my old thermostat wiring system a S1-THEU21P7S and The wiring of my new Sensi UP500W thermostat as guided by Sensi support. On the Sensi thermostat setup the outdoor setting is HP1, the indoor setting is on EL2 and I tried both o and b settings in the options menu. Any ideas would be greatly appreciated.
Size:  33.7 KBName:  New-Emerson-UP500W.jpg
Old 01-09-17, 09:52 AM
You need to put a jumper between RH and RC.
Old 01-09-17, 11:55 AM
Received 1,194 Votes on 1,105 Posts
As shown in the picture.
Old 01-09-17, 02:18 PM
Emerson Sensi UP500W Thermostat Installation Issue
It has a pre built in jumper for RC and RH see below. Or do I need another jumper in addition to the on in the picture. Thanks.
Name:  RC-RH Jumper.jpg
Last edited by PJmax; 01-09-17 at 03:53 PM. Reason: reoriented picture and added label
Old 01-09-17, 03:10 PM
I'm not seeing the jumper.
Old 01-09-17, 03:43 PM
I highlighted the jumper area. Since the red wire jumper isn't cut.... it's considered in place.
I blanked the mac address and security code.
Did you get the programming correct ?
1 = connect network
2 = F
3 = HP1
4= EL1
5 = O
6 = ON
Old 01-09-17, 05:09 PM
Thanks for that editing pjmax. No, I currently have it set on EL2 because I thought since I had a W2 wire on the old one it meant i had a secondary Aux heat. I will change it back to EL1.
