C Wire Older Thermostat
Old 01-23-17, 06:03 PM
I have been reading several threads on this forum but have yet to find a solution for my home. I have an older Gas Furnace and Air conditioning unit, there is no control board per se for the thermostat, just wires that are connected to other wires.
I am trying to find a way to hook up a C wire, can I simply connect this to Ground in the furnace or is this a 24V supply wire?
The schematic that is attached to the unit
The unholy wire mess, the brown wire harness on the left goes to the AC unit outside. The brown wire harness on the right is going to the thermostat.
Old 01-23-17, 06:19 PM
Received 3,324 Upvotes on 2,985 Posts
Welcome to the forums.
You have a C connection there.
Do me a favor and carefully pull the wiring apart a little.
I need to see the splices coming in from the A/C condensor.
Old 01-23-17, 06:41 PM
Thank you, a diagram I did of the connections, would the red wire to/from the condensor be the C wire?
Picture close up
Old 01-23-17, 08:47 PM
You drew a nice representative diagram but you didn't put any of the furnace nomenclature on it.
For example.... the gas valve has three letters on it.
P = pilot valve
C = common
M = main valve
Notice the red wire from the condensor connects with the C connection on the gas valve which also goes directly to one side of the transformer. That is your C connection.
Old 01-23-17, 09:01 PM
Thanks, I am still trying to figure out what all the connections are. now I just need to go buy some 18/5 wire. The thermostat is only 10 feet away in a single level home so I just need to run it through the attic.
Old 01-23-17, 09:26 PM
Houston204's Avatar
Received 72 Upvotes on 65 Posts
The heavy yellow wire to the gas valve is common according to the wiring diagram.
If the thin yellow wire lands on the same terminal it will also be common.
Old 01-23-17, 10:32 PM
The two center taps are joined anc connect to red wire
Old 01-23-17, 10:41 PM
Yes.... and they are all common.
Old 01-23-17, 11:15 PM
Thanks all, looking forward to getting this wired up
Old 01-24-17, 08:37 PM
Thanks everyone, ran new cable and everything works great.
Old 01-24-17, 08:41 PM
Nice job..... well done.
