Add C Wiring to transformer
Old 01-26-17, 03:08 PM
Hi,
I didnt want to hijack other thread so I just want to ask simple question. I have 4 heating zone. The heating system is hot water boiler with baseboard radiant. Attach are two pic, first one is current, second is what I'm trying to do.
Current Wiring:
I want to add "C" to my new (4) Wifi thermostats. Will this work?
Name:  My New Stat.jpg
Can you please tell me if that will work? Let me know if you need more details.
Thanks,
A
Old 01-26-17, 05:12 PM
Received 408 Votes on 384 Posts
Yes...... and good to see you changed the wiring colors to the correct colors.
You should invest in a 60-80va 24vac transformer. You probably have a 40va and it will be screaming.
Old 01-26-17, 06:47 PM
This is the one I have now:
Its pretty old, no labels, but I will look for it again. It does make some noise but its not crazy at the moment since I only have 2 connected.
Thank you so much,
A
Old 01-26-17, 10:01 PM
A 40va transformer won't run 4 zone valves and 4 wifi stats for very long.
Transformer-75VA-120VAC-24VAC
Old 01-27-17, 06:54 PM
What about this Honeywell AT175A1008?
https://customer.honeywell.com/en-US...d=AT175A1008/U
Old 01-27-17, 07:16 PM
That will work too. Shop around as it can be pricey.
