Lux thermostat replacement
Old 02-03-17, 04:49 PM
K
I just bought a new house and was wanting to change the thermostat to a newer programmable one. I have done this for family and friends before but the wiring on this one is confusing me. The old thermostat is a luxpro DM2110 it has 5 wires hooked to it and one jumper. The 5 wires are R G B W2 and Y. The jumper goes from W2 to E. The new thermostat is a lux TX9600TS. Any and all help would be appreciated
Old 02-04-17, 07:35 AM
C
Received 2 Votes on 2 Posts
Seems like you have a heat pump, but please post the make and model of your heat pump and air handler so we can be sure to give you good advice.
Old 02-04-17, 08:55 AM
Houston204's Avatar
Received 17 Votes on 14 Posts
Posting the model number of the outdoor unit would be a good idea.
I would expect the old budget thermostat to have had a jumper between Y and W1 like the new one has in the wiring diagram for heat pump application.
Name:  Lux TX9600TS.jpg
Makes me wonder if you even have a heat pump.
Old 02-04-17, 02:35 PM
K
Thanks guys.
The outsife and inside units are both Rheem. The outside unit is a 13PJL36A01. And the inside is a RHSL-HM3617JA.
Old 02-04-17, 02:46 PM
K
the current thermostat
The wiring in it
Old 02-04-17, 02:58 PM
Houston204's Avatar
Yep, you have a heat pump.
Red = Rc and Rh
Green = G
Yellow = Y and W1
White = W2
Brown = B
Old 02-04-17, 03:04 PM
K
Awesome OK thank I will wire it up here in a little bit. Thanks again
Old 02-04-17, 07:00 PM
K
That did it. It is running great. Thanks again for everything.
Old 02-05-17, 02:14 AM
Houston204's Avatar
Did you install a piece of wire to connect W1 and Y as shown in the diagram?
