Thermostat totally blank after disconnect/connect
Recently I purchased a different thermostat and installed it by myself. When the new one was installed, it did not work. I thought it was broken and placed the previous thermostat back on.
The previous one does not work either. It was perfectly working yesterday before removing it.
Now I tried to reset the system with blaker on/off. Furnace on/off.
The thermostat screen is blank and no sign of power. Furnace is not working at all.
I am thinking this may be related to blown fuse? I may have touched two wires together by accident during the replacement process?
The one I want to put back on (the previous one) is Honeywell Peaksaver thermostat. Does this model have a fuse?
Welcome to the forums.
There are no fuses in the thermostats. The fuse would be in the furnace.
How many wires are on the thermostat ?
Was there a C connection/wire involved ?
You're close...... W, C, R/Rc are valid terminals.
Not sure what K is. If you have A/C.... maybe it's a Y ?
Ok. Since you lost power and you do have a C involved..... hopefully you just lost a fuse.
Go to your furnace. Remove the lower blower door. You should see a control board there.
It should have a fuse on it. If you can't see a fuse post me a picture of the board or it's part number. http://www.doityourself.com/forum/el...-pictures.html
Those are basically automotive fuses. Could probably steal one from your car if you don't any handy.
Thanks we checked our car but it uses a different type of fuse.
Unfortunately it was already past 11pm and all the stores were closed..but will be able to get one tomorrow
Thanks again for saving us!
