Nest- no power to Rh with common connected
Received 0 Votes
Hello! first time poster so please be gentle.
I recently bought a Nest for my home. Furnace is a Lennox 80UHG with a Surelight Integrated control board.
When I removed the old thermostat, the wires were connected to W1, Rh and G. The Nest would not stay charged, so I read enough to realize I would need a common wire. There were additional wires in the cable, but they were not hooked up at either end. So I opened the furnace, and connected the spare blue wire to the C terminal on the control board.
When I hook up the blue wire to the C terminal on the Nest base, I get the red symbol indicating no power to Rh...but if I remove the common, it all works fine
Any ideas what could be causing this?
Thanks
Thanks
You either have a defective nest or the 24vac is sagging.
Use a meter to check from C to R at the board when the nest is connected and not connected.
Received 0 Votes
The wire colours at the control board all match up with the base.
When I took the original thermostat off, the Rh and the W1 wires were the wrong way around. I did not know this at the time, so I hooked the Nest up the same way, and it worked fine (but no charging). Since reading about this, I noticed they were reversed, so I swapped them. The Nest still does the same thing, no matter which way round R and W are. It works, but does not charge, and connecting the C wire stops it working.
Based on the voltages you measured.... the stat is not charging.
I'd say the nest has a problem with it's charging circuit.
Received 0 Votes
@Astuff...there are additional wires, I had tried the orange initially and am now on the blue, so it's not that.
@PJmax, Houston204, thanks, I will contact Nest about this.
Thanks for letting us know how you made it out.
It's especially helpful to others that have or will have the same problem.
Received 0 Votes
I've been the guy trying to solve a problem and finding dead threads...didn't want my thread to end up that way...
https://www.xkcd.com/979/
