Is this 2 or 3 wire thermostat setup?
Old 04-24-17, 03:24 PM
Question Is this 2 or 3 wire thermostat setup?
I want to install a new thermostat and some state they require a 3 wire, and some a "C" wire, and some say a "2 wire" is fine. I am thinking I have a 2 wire but can somebody confirm this?
If in fact it is a 2 wire, is there a way to convert it to 3 wire?
Thanks in advance.
jim
Old 04-24-17, 03:30 PM
Received 4,149 Upvotes on 3,726 Posts
Welcome to the forums.
Red + white + green = three wires.
Your stat is currently set up for two wire heat.
You should be able to connect the green wire at the furnace end for C use.
Go to the furnace and look where the wiring connects. There should be a C terminal.
If not... shoot and post a few pics pf what you see. http://www.doityourself.com/forum/el...-pictures.html
Old 04-24-17, 07:25 PM
Ahhh, I see. Thank you. So this is what I see at the Zone box:
So I see the green wire on both ends. What I don't see is a place to tie it in at the zone box unless is shares a terminal with the white or red.
Jim
Old 04-24-17, 07:44 PM
Ok.... this pops up about once a month.
I need a picture of the entire control.
Do you have a meter ?
Your control has T T ..... not R and W. Those red and white wires are connected arbitrarily.
With the meter I'll tell you how to ID them and locate C.
If this is your exact box.... including the terminals in red and blue .... then I don't need a picture.
Old 04-24-17, 08:15 PM
Ok, that looks like mine:
Old 04-24-17, 08:21 PM
The lower left:
That appears to be the same as your pic
Old 04-24-17, 08:23 PM
Ok.... so your stat wires are randomly installed on the TT terminals. We'll need to convert those letters.... TT to R and W. I will help you. It's very easy.
Since this is AC... probe polarity is not important.
We will be working with the board that the stats are connected to.
Attachment 80008
1) Check for 24v at the live R and live C terminals I have labeled in red and blue.
Those are set screws and easy to put probes on.
2) Remove the two wires from the TT terminals on the port the new stat will be on.
3) Leave one probe on live C and touch the other probe to either TT terminal. The one that shows 24vac is the R terminal. The other one is W.
4) Put the probe on live R and the TT terminal you tested as R. There should be 0v.
5) Leave the probe on live R and move to the W terminal. You should measure 24vac.
You're done. Tell me which T terminal is W and which is R.
