Replace two thermostats with a single unit
Received 0 Votes
Hello,
I have a separate heating (natural gas boiler with radiators) and air conditioning (forced air heat pump) unit which are not connected at all. Each unit has a separate thermostat (see below, round unit is for heat and square unit is for air conditioning).
I would like to modernize these thermostats and replace with a single unit. The air conditioning thermostat has three wires (red, yellow, green) which are not labeled. The heating thermostat has two wires (red, white) which are also not labeled.
Note: The A/C thermostat has a heat option but it is not in use.
I think the model numbers for the thermostats are as follows:
Heat: Honeywell T87F 2873 3 9744
A/C: Carrier T87F 2543 2 HH01AD040 BX4
Unfortunately I cannot find any manuals or wiring diagrams for these old thermostats.
I'd like to know:
(1) is it possible to replace these with a single unit?
(2) if yes, do you have any advice? I'd like it to be programmable, but wifi is not necessary.
(3) does anyone have an idea about this non-labeled wiring? Or have a link for them?
Thanks!
Front view of each thermostat, A/C to left and heat to right:
NOTE: The following photos should be rotated 90 degrees, I don't know how to do it in this forum...
Cover of A/C removed showing model number:
Wiring of the A/C:
Close up of A/C wiring:
Cover of Heat removed showing model number:
Wiring of the Heat:
I'd like to know:
Thanks!
Wiring of the A/C:
Wiring of the Heat:
I recommend a Honeywell TH8321R thermostat.
C is optional but it looks like you have an extra blue wire fore C.
Connect green to G yellow to Y and red to Rc.
Connect the heater red wire to R and the heater white wire to W.
No jumper between R and Rc on the new stat.
Received 0 Votes
Houston204, I have one additional question. You said "C is optional". Maybe I'm wrong, but I understand without a power source the thermostat is drawing power only from the batteries. I'd prefer to have a wired power source so that the heat doesn't go out in the winter time when the battery dies.
Because I have two separate units, will connecting the C wire cause a problem? I was worried that the thermostat might create a circuit between R and C to power itself, and in my case R is going to the gas boiler and C is going to the A/C unit.
Running from the batteries is something that I would avoid if possible as well. I would not install the AA batteries at all. Leaking batteries the most common reason that I replace digital thermostats.
The thermostat draws power from RC and C.
Connect the blue wire to C at the air handler and at the new thermostat.
The button cell battery is all that is required if you have a common wire, and I believe it is already installed, but you must pull a small piece of tape to allow it to work.
