need help upgrading for home automation
Received 0 Votes
I currently have two Trane units in my home. The current configuration is heat pump to fossil fuel @ 41 degrees f (temprature sensors for each is mounted on the heat pump). The equipment was installed in 07-08 and uses the Vision Pro IAQ-3 wire with the EIM setup.
Would like to upgrade my thermostats to use with Alexa and Samsung Smart Things hub. What direction should I take?
thanks
thanks
According to the Honeywell website the Prestige IAQ and gateway support Alexa.
The Honeywell Prestige IAQ is the modern version of your current Honeywell IAQ. The grey EIM looks almost exactly like your current white EIM but it only uses 2 wires between the new stat and new EIM.
These are some examples ...
https://yourhome.honeywell.com/en/partners
https://www.amazon.com/Honeywell-YTH...AQ+and+gateway
