Where to connect C wire - Trane XE900
Received 0 Votes
Hi,
I'm looking to change my current thermostat and I'll need a C wire. I have unused wires coming from the furnace to the thermostat, however I have no clue where to connect the C wire. The compressor is a Trane XE900 and runs heat pump and A/C.
I have 4 wires in use in my current thermostat.
This is the schema
And a picture with, where I think I have to connect the C wire
Could you help me?
Thanks
This is the schema
Could you help me?
Thanks
Bottom picture - go a bit lower and zoom in on the left and post again. The blue wire is most likely the C you need. It should also be connected to a wire going to your outside compressor as the compressor needs a C as well.
Yup. That thick blue wire in the front is C. For sanity use the spare unused blue wire to go to the thermostat. Remove the blue wire nut - add the thin blue wire - then put the wirenut back on - will have thick blue, thin blue, and the old white.
Are you sure that you have a heat pump? The thermostat wiring is only set up for a/c and electric coil heat.
It's hard to read the colors in that schematic. The C connection is also grounded in that air handler so any metal chassis connection will yield C.
Agreed.... blue wire. Was able to read Bl off the print.
The XE-900 shows it can be a heat pump. But you'd need to post the actual model number off the condensor unit for confirmation.
If it was a heat pump...... the outside condensor would be running in the winter.
Does that happen ?
Does that happen ?
