Nest E Wiring Help
Old 12-20-17, 05:09 PM
Nest E Wiring Help
Hi,
I stumbled across this forum while searching the net for information on wiring a Nest-E thermostat. The website says my system is compatible, but recommends professional installation. I'm not interested in paying $100 for someone to come out and hook up a couple of wires, so I'm hoping I can find some cheaper information.
My old thermostat is a White-Rodgers 1F95EZ-0671. It has the following connections:
C - A separate light blue wire (builder did some redneck engineering to get a C wire. Ran a 2nd cable)
RH & RC - Jumpered and a red wire connected to RC
O/B - Light blue wire
W/E - Brown wire
W2 - White wire
G - Green wire
Y - Yellow wire
The Nest-E has the following connections:
Y1 - Yellow wire should go here
G - Green wire should go here
R - Red wire should go here
W1 - ??? Brown or white (or both)?
C - Separate blue wire goes here
*OB - Blue wire goes here
It all seems pretty straightforward except for the brown and white wires. It's not clear where they should go.
The Nest-E manual says that if I have a W2 wire, I can connect it to the *OB, but a wire is already there.
Any suggestions on how I should connect those wires? Thanks.
Old 12-20-17, 05:19 PM
UPDATE: I pulled the cover on the air handler to see how it is wired. It has the following connections on the circuit board:
C - blue wire
R - a black wire which is connected to a red wire
G - green wire
Y/Y2 - yellow wire
O - brown wire
W1 - black wire, but I couldn't figure out where it is connected.
W2 - no connection
Y1 - no connection
L - no connection
This wiring leads me to believe that I don't have an AUX heating unit. The system was replaced several years ago. The original system did have Aux heating, so I'm thinking I have some leftover wiring from that.
Old 12-20-17, 05:21 PM
Houston204's Avatar
Received 10 Votes on 8 Posts
It looks like you have solved your own question.
Old 12-20-17, 05:33 PM
Received 340 Votes on 318 Posts
The nest will support AUX heat on W2. Emergency heat on the *
White on W2 and cap off brown or use the * for brown and program it for E heat.
When the nest is in heat pump mode.... W1 is disabled.
You had a white on W at the stat. It must change to black thru a splice.
It is VERY confusing when the stat colors don't match the colors at the air handler. I would follow the colors at the stat.
You can right click on this diagram and select "view picture" for a larger view.
These are not the same colors but the descriptions are.
C - A separate light blue wire ------> C
RH & RC - Jumpered and a red wire connected to RC -------> Rh
O/B - Light blue wire -------------> O/B
W/E - Brown wire ---------------> *
W2 - White wire -----------------> W2
G - Green wire -------------------> G
Y - Yellow wire ------------------> Y1
Old 12-20-17, 05:58 PM
Houston204's Avatar
I wonder why the new Nest E thermostat would be less capable.
https://www.google.com/search?q=Nest...b3kZ7pPyocYEM:
Old 12-20-17, 06:06 PM
That looks like a stripped down version for those that don't need all the connections. No emergency heat support.
So for the nest E
O/B - Light blue wire ------------->* O/B
W/E - Brown wire ---------------> no connection
W2 - White wire -----------------> W1
