Go Back  DoItYourself.com Community Forums > Heating, Cooling, Air Conditioning, Ventilation and T-Stat Controls > Thermostatic Controls
Reload this Page >
Nest 3rd Gen Cooling Stage 2 not working but Heat pump cooling is working
Old 05-05-18, 12:29 PM
W
I spent more than an hour with Nest tech support but they were not able to fix this issue. They are sending me a new base, but I don't think that will resolve the problem. I have a Goodman heat pump and a Nest 3rd Gen tstat. The Cooling Stage 2 does not provide cold air, but when I run a test, the Heat Pump Cooling works fine. The compressor and fan are both running for Cooling Stage 2 but the air is not cold. I suspect that the reversing valve is not opening. Any thoughts on programing changes that will get the system working. As mentioned above, the Heat Pump Cooling works perfect.
Thanks, Will
Old 05-05-18, 01:02 PM
Are you sure you have a 2 stage compressor? What is the model # on the outside unit?
Old 05-05-18, 01:09 PM
W
Unfortunately, I can't read the Model number. It's worn off. However, I have two yellow wires to the tstat
Old 05-05-18, 01:11 PM
Received 1,324 Votes on 1,224 Posts
Welcome to the forums.
You're saying it cools fine in stage 1 but not stage 2 ??
That wouldn't be a reversing valve issue. Same valve operates in both stages.
Old 05-05-18, 01:14 PM
W
Yes, G, Y1 works well, but G Y1, Y2 does not work. The compressor and fan are running with G, Y1, Y2 but the air is not cold. I suspect the reversing valve is not opening.
Old 05-05-18, 01:29 PM
W
Thanks for the feedback. I just unplugged the Y2 wire and it seems to be working well. Not sure why that wire is needed.
Old 05-05-18, 01:39 PM
We'd need further info on the condenser to comment further.
You can look down inside from the top and see if there are two compressors.
You can let us know what low voltage wiring is connected outside.
