Honeywell WiFi thermostat power flickers on and off
I just installed a WiFi thermostat and I am not having constant power. The thermostat will power up, but when I go to adjust the the time and date to set it up it loses power, then a little while later power comes back. Also if I play and jiggle the thermostat will power on and off.
I am trying to figure out if it is a "C" wire problem or if I may have a defective thermostat.
Thank you for help!
Thank you for help!
I would recheck the wire connections to the thermostat and verify that the mounting screws haven’t damaged the stat wire before trying to exchange the stat.
Problems with Honeywell WiFi thermostat
I am have problems installing a wifi thermostat. I am not getting constant power causing the screen to turn on and off. I tested all the connections and they all show 26v. Honeywell said my thermostat may be defective but I am having the same priblem with a second thermostat. Any suggestions?
thank you!
thank you!
