Nest Compatibility / Wiring Questions
#42
Received 0 Votes
Should I try and bypass the ICM? Everything seems to be connected properly
**update**: contacted nest support and they asked me to hook everything back up minus the c wire. Everything seems to be working okay again. Is it safe to run long term like this?
#44
Received 0 Votes
Everthing seems to be working fine with the nest and the S5 - 2 Off.. I think I'll remove the ICM just to see if allows me to run the C wire.
When I remove the ICM, is everything I need to adress at the timer itself or would I need to change any switches or settings anywhere else?
