Hooking up Nest to Trane Heat Pump
Received 0 Votes
Was wondering if someone can tell me how to hook up my Trane Heat Pump to the nest thermostat. Here is a picture of the wires in the current thermostat, I am just not sure where they connect to the nest. Thanks in advance.
Steve
Steve
Use the outer labels on your old thermostat and treat the X2 as an E
I see that there is an extra wire behind the others. It would be helpful if that one could be used as a C as Nest works better with one. Trane refers to it as B. Would need to see the wiring at the air handler.
Received 0 Votes
Thank you. It was the x2 wire that was throwing me off. What is that wire for, aux heat? The extra wire you are referencing, is that the one in the bottom of the picture not hooked up to anything? Why would that be?
W1 should be set up as Aux heat - runs at same time as heat pump. X2/E is emergency heat at the thermostat. When you set the thermostat to emergency it doesn't turn on the heat pump, just this wire. If you only have electric (no gas furnace) the two wires are often connected. Need to see at air handler.
Extra wire- hard to say without knowing what it is attached to on the other end. Could have been a change to your system or when thermostat was replaced they didn't know what to do with it.
Just one correction.... W1 is not active on the nest when in heat pump mode.
You need to use the W2/AUX terminal instead.
The heat pump is stage one or W1 heat.
Received 0 Votes
Thanks guys. Just so I’m clear on this....does this look correct:
current wire Nest wire
Y2 Y2
X2 *
W1 W2/Aux
R Rh
O Ob
Y Y1
G G
and if possible, the extra wire should go to the C.
how do I know if that extra wire can go to the C? Can the next function without the C wire?
also, when hooking up the nest to a heat pump, does everything function as it should?
thanks again
Y2 Y2
X2 *
W1 W2/Aux
R Rh
O Ob
Y Y1
G G
thanks again
Those connections look good. You will have to tell Nest if you have single or dual fuel. The o/b is an O, and * is emergency heat. Nest doesn't need a C most of the time but when it does strange things happen. You need to find the other end of the wire to see if it can be used.
Nest is quirky and follows unique algorithms so you will likely find something acting not as what you would expect.
Received 0 Votes
Hey guys, so I just used a multi-meter to test that un-connected wire at the thermostat and there was no reading. So I am assuming, if that is meant for a C wire, that it would also be disconnected at the handler? I am going to check the handler tonight....I think the wires will be located on the roof with the unit itself. If that is the case, Do I just connect the wire at the handler to the C (B) terminal?
Thanks
Thanks
The wiring access area on an air handler will usually be very near where the electric connects to it.
Received 0 Votes
Alright Gents....so i don't have an attic, and I don't see anything in the garage, So I am assuming the wires are in the unit on the roof. Here are some pictures. The model # is Trane 4WCZ60498A1000. Any idea where the ends of the wires would be located in this unit? There is no easy access panel. Thanks again for the help.
Received 0 Votes
Thanks Astuff. I looked in there a few days ago and saw wires, but I didn't see an end to them. I will go up there again and take some pictures and post. Appreciate the help
Received 0 Votes
Astuff--Alright, found the panel. Here are a few pics. Upon closer inspection at the thermostat, the extra wire is blue. So this is what I a seeing at the unit itself (the 2 pics). Is it as easy as connecting the small blue wire to the large blue wire that has the wire nut on it? The large blue wire is connected to the B port on the panel (sorry, that picture is blurry) If it is that simple, is there a reason they didn't connect the C wire in the first place?
#21
Yes, it should be simple. Be careful putting the cover back on that you don't pinch a wire.
Hard to say what happened with not connecting that wire. Maybe they had an issue with the original thermostat? Hopefully not but maybe blue wire is bad.
#22
Received 0 Votes
Thanks Astuff. I appreciate the help. Last question, once I connect the B wire at the unit, I can use the B wire on my old thermostat (pictured above) without an issue, correct? Right now that thermostat is battery operated. If the blue wire is good, the old thermostat should function without batteries, correct?
#27
Received 0 Votes
Ok, after 3 weeks with the nest I have noticed some weird behavior and am thinking about returning it.
I got it hooked up and it was working as it should (both stage 1 and stage 2 cooling were working as they should). Then about 1.5 weeks after getting it, the thermostat said it was cooling, but warm air was coming out of the vents ( I don't think it was the heat, i think it was just outside air). After a re-set, the issue resolved itself. We even had an HVAC guy come out and clean the coils just to be sure it wasn't the unit. Now, this morning, the same thing happened.
Astuff, have you ever heard of this happening?
#28
I've seen some reports of this. Some solved with maintenance which you already had done. Others had Nest replace their device but I don't recall if it solved things long term.
Returning it would be the safest thing to do.
#29
Received 0 Votes
Thanks Astuff.
And I should be ok connecting the C wire to my previous thermostat so it can be powered now without batteries?
Would this nest issue be causing any harm to my system?
#30
Received 0 Votes
I will miss the ability to control temp from my phone. Astuff, i was thinking about possible replacing it with a basic honey well wifi thermostat (RTH6500WF). Would my system be compatible with this, and if so, how would the wiring work?
#31
Received 0 Votes
Sorry to blast you with responses, but the Emerson Sensi looks interesting as well....Can you tell me how I would connect the my wires to this unit as well? Thanks again
