Hot air blowing in cooling mode on Nest
Old 06-20-18, 05:56 AM
Hi,
I have two nest controlled unit. One is a heat pump (the picture with black border) and a regular furnace type unit (the picture with yellow border). The heat pump blows hot air in the cooling mode. The wiring looks different for different nest controllers. As far as I remembered, my two nests are not the same generation either. The heat pump is an older generation. Please help!!!
Old 06-20-18, 06:18 AM
W
Received 63 Upvotes on 55 Posts
Have you used the Nest support function?
https://nest.com/support/thermostats/#troubleshooting
Old 06-20-18, 08:54 AM
I follow the instruction but no help.
Old 06-20-18, 05:04 PM
Received 3,951 Upvotes on 3,544 Posts
Welcome to the forums.
A couple of issues here.
Why are there two red wires ?
You have a brown wire in the O/B spot which is correct but the stat may not be programmed correctly. What is the make of the outside A/C condenser ?
I would also move the white wire to the W2/AUX location.
Old 06-20-18, 07:38 PM
I really do not know. HVAC guy put it.
You have a brown wire in the O/B spot which is correct but the stat may not be programmed correctly. What is the make of the outside A/C condenser?
Trane XLi 4TWX6036H1000AA
I'll try
Thanks
Old 06-21-18, 10:59 AM
Ok..... move the white wire to W2 and make sure the nest knows you have a heat pump with AUX backup heat. In the setup you need to tell it that the O/B terminal needs to be set to O operation.
