How to remove York thermostat to install Google Nest
Old 07-11-18, 07:07 PM
G
I am trying to remove a York thermostat. Model S1-THEC11P5Y. However, I cannot figure out how to do that without uprooting it all from the wall. Please help. I am trying to install Goolge Nest after removing this.
Last edited by goutamchakg; 07-11-18 at 07:08 PM. Reason: Order of images after test
Old 07-11-18, 08:08 PM
Norm201's Avatar
Received 317 Votes on 284 Posts
Old 07-11-18, 08:11 PM
A
Received 49 Votes on 44 Posts
In pic 2 you can see two tabs on the bottom. Pull both down and out. Should pull off the front exposing the back plate and the screws.
Old 07-15-18, 11:49 AM
G
Astuff’s suggestion worked. Thanks
My original thermostat had a jumper wire between RH and RC. Nest instructions suggested not using any jumper wires. Any suggestions about whether I should put it in or keep it out
Old 07-15-18, 11:59 AM
Houston204's Avatar
Received 17 Votes on 14 Posts
Nest will not require a jumper between the R’s.
