Lyric T5 Help
Old 09-21-18, 11:37 AM
L
Lyric T5 Help
Hello new here and tried to find a answer but haven't got it yet.
I'm trying to upgrade my mothers house with a Lyric T5 but I can only get hot air. I've take pictures of everything as the sticky states. The Air handler is a Trane 2tec3f36b1000aa. I tried to find the Y/W/G/R/C panel but couldn't find it or doesn't have the normal looking one.
I hooked up the T5 same as the honeywell except for the jumper as the T5 states its not needed. White has all 3 white colors connected to it on the air handler, Orange is white as well, Red is red, Blue is C, G is green, Brown/black not connected.
Old 09-21-18, 02:24 PM
Received 1,035 Votes on 959 Posts
Welcome to the forums.
AUX/E -- white -- AUX
G -- green -- G
O/B -- orange -- O/B
Y -- yellow -- Y
R -- red --R only (switch up)
? -- blue -- C
Equipment set up options....
200 - system type ----> heat pump
205 - equipment type --> (heat pump) air to air
218 - reversing valve --> O/B on cool
Old 09-22-18, 12:10 PM
L
For 220/221 should it just be 1/1?
Its what I did and its working but just wanted to make sure. Thanks for the help.
Old 09-22-18, 01:22 PM
Usually when the default value is correct.... I don't list it.
220 - cooling stages - 1
221 - heat - 1 and AUX -1
