Replacing 1965 line voltage thermostat with smart/wifi type
So I have 1965(ish) Electric Radiant Ceiling heat. It heats up the drywall and radiates downward. It is nice heat...no furnace sound etc...but it's expensive. So this thermostat I have in the picture no longer works and I don't need this thermostat anymore. Long story....
My question is, are there smart thermostats or even newer type digital thermostats for this type of heat. There is a hot and neutral wire...then the two red wires(which go out of the box up the wall from what I can see) I assume go to the ceiling wires which in turn heat up.... I haven't been able to find much on google, etc.
Thanks in advance!
Thanks in advance!
Last edited by PJmax; 03-05-19 at 05:27 PM. Reason: cropped/resized/labeled pictures
You need a 240v thermostat. There are programmable/digital ones but no wifi or "smart" ones.
You'll need to supply the smarts to program it.
240v line thermostat
I was cruising around and I came across this thermostat. Looks interesting.
I don't know anything about it yet. It will work for you.
Stelpro Maestro thermostat
