Upgrading to Nest thermostat problems
Old 03-25-19, 06:44 PM
E
A few days ago I ended up buying a Nest Gen 3 thermostat . Writing down the wires , what they are connected to as well following Nest instructions.
But now there is an issue that the furnace fan does not go on, even though the furnace turns on.
And testing the Nest thermostat the fan sounded like it tried to kick on but never did.
Everything looks like it is wired correctly, I even re-seated the green contact.
Here is pictures of everything for any suggestions on what is wrong.
Last edited by PJmax; 03-25-19 at 08:06 PM. Reason: cropped/resized/labeled pictures
Old 03-25-19, 08:10 PM
Received 3,424 Upvotes on 3,070 Posts
Welcome to the forums.
Made me work here tonight. Moved thread. Removed second one. Resized pics for the board. You need to pre-size the pics before posting. 600x600 max.
You don't have a furnace...... you have a RHEEM or RUUD heat pump with electric backup.
Is that correct...... NO gas furnace ?
Move the white wire from * to W2/AUX.
Old 03-25-19, 08:27 PM
E
No it is a Rheem natural gas furnace and a Electric heat pump.
Thank you for cleaning up the threads.
There is also a pro setup on the Nest. Have not went through that.'
Attached image is what it current thinks I have connected
Old 03-25-19, 08:40 PM
Ok... you still need to move the white wire.
In pro setup..... you need to program the nest as DUAL FUEL. You need to program the O/B to B.
Old 03-25-19, 09:10 PM
E
That seemed to do the trick.
Thank you so much for your help !!
Was expecting a cold night
Old 03-25-19, 09:19 PM
The reason for the dual fuel programing is because the gas furnace and the heat pump cannot run at the same time. The heat from the furnace will cause the heat pump to overheat.
Old 03-26-19, 07:12 AM
A
Received 83 Upvotes on 75 Posts
There probably is a dual fuel board that protected the heat pump. Might also have a outdoor thermostat that controls cut-over.
