Ecobee thermostat needing a C wire, Unused blue wire in furnace
Old 07-17-19, 09:32 AM
C
I recently bought an Ecobee thermostat and it’s needing a c wire to be connected. Upon looking through the wires from the thermostat there was a blue wire tucked away in the wall. When I looked inside the a/c unit this blue wire is not connected to anything. I have a Rhemm rhll-hm3821ja model. I want to assume that this is the common wire. I’m unsure of what to do at this point or what to connect it to if possible. It looks like there’s a brown wire connected to the c terminal on the control panel that is then connected to a black wire. That’s where I’m confused. Any help would be greatly appreciated.
Old 07-17-19, 02:03 PM
Geochurchi's Avatar
Received 146 Votes on 134 Posts
Hi, if you trace that brown wire it should go to one side of the transformer, if so connect the blue to the black and brown.
Geo
Old 07-17-19, 04:21 PM
C
Thank you very much Geo, it worked.
