Rc840t-240
Old 08-16-19, 01:10 PM
Rc840t-240
Trying to install the rc840t-240 on 240 window unit with external thermostat so it will cut ac off a certain temp. Having trouble gettin it wired correct
Old 08-16-19, 01:42 PM
Received 330 Votes on 308 Posts
Welcome to the forums.
The best way to use a relay like that is to mount it on a 4" square electrical box and use an A/C receptacle in the cover.
So what are the problems you are having ?
How are you attaching it to the A/C ?
Old 08-16-19, 03:14 PM
Rc840t-240
Ran cord from wall plug to a new box with a plug and tied wires from relay to back side of plug . The blue wire trips breaker if i hook it to red
Old 08-16-19, 03:50 PM
Ok.... so if you look at the diagram..... the new line cord gets connected to L1 (black) and L2 (blue).
The A/C or receptacle connects to red and L2. L2 is basically the common but not neutral.
Old 08-16-19, 05:21 PM
Rc840t=240
I have a honeywell rth111 battery operated tstat . Will it work
Old 08-16-19, 05:35 PM
Certainly. You'll connect R of relay to R of stat and W of relay to Y of stat.
Old 08-16-19, 05:48 PM
Do i check across r and y for 24 volts if so the 24 volts is not there
Old 08-16-19, 06:01 PM
The thermostat is not supplying any voltage out.
What's happening is on a call for cooling..... it's shorting R and Y together.
Old 08-25-19, 05:52 PM
I changed tstat. I WIRED ALL THE BLACKS TOGETHER . WIRED LINE 2 TO RED ON THE RELAY AND WIRED THE BLUE TO THE RED SIDE OF MY POWER CORD. THE RED LIGHT COMES ON BUT I ONLY HAVE POWER TO LINE ONE BLACK 110
Old 08-26-19, 05:01 AM
Geochurchi's Avatar
Received 15 Votes on 15 Posts
Hi, L2 will be connected to your cord along with the Blue conductor from the relay and also to one side of the new receptacle in the box which will plug into your existing wall receptacle.
Black from relay will connect directly to the other L1 from the other side of power cord.
Red from relay will connect to the other side of the new receptacle
Geo
