Help replacing Nest with Honeywell RTH9585WF1004
Hello Everyone,
I was attempting to replace my Nest thermostat with a new Honeywell RTH9585WF1004. I was installing the wires into the Honeywell unit and I had 2 wires left. W1 and OB. The Honeywell only has 1 wire slot with W-OB on it. Has anyone ever run into this before.
My air handler has all the same wires attached. Should I combine the W and OB wires?
Any help will really be appreciated.
-Beau
-Beau
Welcome to the forums.
You've got an awful lot of bare wire at the control board. You don't want those wires touching.
What is the heating system.... a two stage gas furnace ?
You may need a dual fuel thermostat because if you have a gas furnace..... the heat pump is heating 1, and the furnace is heat 2 and heat 3 and you need the heat pump to shut off when the furnace is running.
We had discussed these stats and dual fuel but I forgot the thread.
I'm fairly certain the Ecobee 3 lite can't be used with dual fuel either.
The Ecobee 3 can and also the Ecobee 4.
Hmm, when I set it up after install it had options for dual fuel and aux heat. It recognized that I had a 2 stage furnace, etc. So, so far so good I guess. I appreciate the reply!
