New Thermostats
New Thermostats
Hi, installed two thermostats with a problem. One thermostat puts the heat on when it is on cool and it falls below the marked temp. It does not put the heat on at all when put to heat, and it only does this if the other thermostat is set to heat. The AC part on both thermostats work correctly. Going out of my mind.
Welcome to the forums.
Are you asking me to guess your problem ?
Without further info..... that's about all I can do.
Thermostats come pre-programmed for standard gas furnaces with split A/C.
If you have a heat pump.... it must be programmed for that.
What thermostats did you have? What did you replace them with?
What type of equipment do you have?
Is this equipment staged?
How was it wired originally? How is it wired now?
Do you have a zoning panel? If so what do you have exactly?
