Nest learning thermostat with trane xr80 furnace
Hi
i have just had a lengthy and frustrating chat with google re the compatibility of the nest learning thermostat and the Trane xr80. Their conclusion was it was not compatible, but i see online posts saying it is. Who should I believe? I would appreciate any advice on this. I have attached a picture of the wires from my current thermostat.
Welcome to the forums.
That picture location is IN your phone.
You need to download it to here..... How-to-insert-pictures.
What model of nest ?
That’s just a conventional thermostat, most any over the counter control will work.
I highly advise against using the nest.
I'm not so sure that's a conventional thermostat. It looks like both the O and B terminals are used. Can't see what the blue wire is on. That would indicate a possible zoning system in use.
R ---------------> red
W ---------------> white
Y ---------------> yellow
? ----------------> blue
O ---------------> orange
G ---------------> green
That’s a good catch. I didn’t note both of those wires connected.
OP, do you have a zoned system? What one do you have?
It is zoned but disconnected at the furnace as I think there are issues with the damper motors. So right now this one thermostat controls the whole house for heat and air conditioning
Will the zoning be reconnected?
Nest doesn’t play well with zoning.
The nest thermostats in general have a lot of quirks and problems that users deal with.
One final question..... is that a Trane thermostat ?
B on a Trane stat is actually C (common)
If the zoning board is disconnected...... you can use the nest.
If the zoning board is still controlling logic..... you can use the nest but you will also need a relay to set the heat/cool mode.
If the zoning board is not connected..... the thermostat wires would have to be spliced thru.
Going to need a picture of the zoning board and the low voltage connections at the furnace.
Sorry it's not easier but there are too many variables to just guess at.
Pictures are ok. Modified as needed.
Confirm the following connection.
Thermostat one connections.
Y -------> yellow
R -------> red
W -------> white
O1 ------> orange
G1 ------> green
B1 ------> blue
System connections
Y ----------> yellow
G ---------> green
Rh -------> red
W --------> white
There is a red wire also on Y. Does that red wire go into that ??? cable ?
If yes..... what is the other color in that cable ?
It looks like black may be that color connected to a blue wire in the equipment cable.
Assuming you are bypassing the zoning board and blocking both dampers open manually.
What model nest ?
MM2 mastertrol zone control (pdf) manual
Y -------> yellow
R -------> red
W -------> white
O1 ------> orange
G1 ------> green
B1 ------> blue
System connections
G ---------> green
Rh -------> red
W --------> white
What model nest ?
