Old thermostat help.
Old 11-13-19, 02:57 PM
N
Hi I have a single pole thermostat two wires radiant hot water heater powered by oil T44A old fashioned thermostat can I replace it with a T410A electric thermostat
Old 11-13-19, 05:14 PM
Geochurchi's Avatar
Received 158 Upvotes on 144 Posts
Hi, if it’s a 2 wire Stat this would work.
https://www.homedepot.com/p/Cadet-Me...21-W/308111895
Geo
Old 11-13-19, 06:45 PM
Received 3,600 Upvotes on 3,228 Posts
Welcome to the forums.
Yes..... you can replace your T44A line voltage thermostat with a T410A thermostat.
Geo's mentioned thermostat will work too.
Be sure to turn the power off to the boiler as there is 120vAC present at that thermostat.
Old 11-18-19, 06:58 AM
N
You guys are the best!
Thank you everyone so much for all of your help we successfully changed the thermostat and no one got shocked
Old 11-18-19, 10:24 AM
Good job. Thanks for letting us know how you made out.
