Heat only nest connection
Old 11-17-19, 07:43 AM
W
Do I need C wire for Nest thermostat if it controls heat only from the gas boiler? If yes where will I have to take it from
Old 11-17-19, 07:48 AM
Received 4,054 Upvotes on 3,637 Posts
Welcome to the forums.
The nest claims it will work without a C wire. I have found that to be 50-50 true.
Most furnaces have a location for a C wire and you would need an extra wire.
We'd need a furnace model number or a picture of the wiring connection area.
How-to-insert-pictures.
Old 11-18-19, 08:18 AM
W
My boiler
The boiler that is operated by Nest thermostat is made by Burnham model 403B
all the connections are made in the box holding transformer
I can attach picture if needed later on from my computer
Thank you for helping me
Old 11-18-19, 10:20 AM
Do you have the nest already ?
Give it a try.
The box you are describing sounds like an aquastat. Remove the cover and look inside. At the top is where the thermostat connects. If all you see is T T ..... there will not be a C connection available.
