Nest E (3) and Nest 3rd Gen (1)
Old 11-18-19, 08:02 PM
I have a Burnham V-74-T furnace, 4 zone, 3 just heat and 1 does heat and AC. Installed 4 Nest thermostats and my furnace is clicking rapidly. Appears I need a common wire for power. Do I need to add a common wire for each thermostat? And how do I do this?
What additional info can I provide for assistance?
thanks,
john
Old 11-19-19, 05:12 AM
Geochurchi's Avatar
Received 161 Upvotes on 147 Posts
Hi, each stat will need a common C conductor to do the install correctly, post some pics of your current Stat wiring and also the control center of the furnace.
Geo
Old 11-19-19, 06:01 PM
Received 4,047 Upvotes on 3,631 Posts
Welcome to the forums.
You've got some issues. That old Argo panel was not sized to run multiple electronic thermostats. It only has a 15va transformer to power the entire board and the relays. It will not power your wifi stats properly.
Technically you'd need to use a another 24vAC transformer to power the nests.
The nest on the heat and A/C should be ok. That thermostat needs to get its C from the A/C.
How many wires between the thermostats and that Argo board ?
You're going to need at least three wires.
