Nest 3rd Gen to control Carlin burner
Old 11-19-19, 11:01 AM
B
I would like to disconnect older "Blue" Heat-Timer EPU-60 CH and start to control the boiler with 3rd gen Nest ( which is already connected to run AC system) after doing some research I came up with the diagram but I would like to double check if this configuration would work properly:
Last edited by PJmax; 11-19-19 at 05:15 PM. Reason: resized pictures/labeled diagram
Old 11-19-19, 05:16 PM
Received 1,610 Votes on 1,482 Posts
Welcome to the forums.
The connection to power the nest comes from the C terminal which must come from the A/C system.
Eliminate the connection from your second transformer to C.
