WiFi thermostat install.
Old 11-19-19, 04:15 PM
Iím installing a new WiFi thermostat in my 17 year old home. The current one is only using 4 wires, but the c wire(blue) is taped off at the thermostat. I looked in the wiring panel in the furnace and it not connected to the c terminal. I do see a white wire on the c terminal at the furnace that is going out to my AC unit. Can I assume itís safe to add the blue wire from my thermostat over the current white wire on the c terminal?
Old 11-19-19, 04:43 PM
Received 4,056 Upvotes on 3,639 Posts
Welcome to the forums.
Yes..... you can add that to the other wire on the C terminal.
The white wire currently on the C terminal and the red wire of that cable that goes to Y or yellow is the line that feeds the outside condenser.
Old 11-19-19, 05:05 PM
Thanks so much for the response
