Replacement for Honeywell T8411R
Old 12-20-19, 08:34 AM
Live in FL, unit runs both heat and central A/C. 24v 2 stage heat & 1 stage cool. But this thermostat has manual changeover from heat to cool. I want to replace with a 7 day programmable T with automatic changeover. I also want to be able to adjust the swing and have Room & Set temps display simultaneously. Any suggestions on replace Brand and Model #? Thanks.
Old 12-21-19, 01:46 PM
Houston204's Avatar
Received 95 Upvotes on 88 Posts
The Honeywell TH8321R is a good option.
The Honeywell Prestige IAQ is a great option but should be professionally installed.
The Ecobee is also a very good option.
I would avoid Nest.
