Thermostat: cycles per hour
Old 12-31-19, 04:13 AM
JOB
JOB is offline
Hello, why would a home owner want more cycles per hour (CPH) versus less for their heating system?
FYI I have a gas fired forced air heat/cooling system with a Honeywell thermostat.
I see more advantages to less cycles per hour involving humidity control and general comfort.
When would more CPH be better than less?
Thank You
JOB
Old 01-01-20, 02:04 AM
Houston204's Avatar
Received 95 Upvotes on 88 Posts
The Honeywell manual gives a description for cycles per hour.
Cycle rate limits the maximum number of times
the system can cycle in a 1 hour period measured
at a 50% load. For example, when set to 3 CPH, at
a 50% load, the most the system will cycle is 3
times per hour (10 minutes on, 10 minutes off).
The system cycles less often when load conditions
are less than or greater than a 50% load. The
recommended cycle rate settings are below for
each heating equipment type:
Standard Efficiency Gas Forced Air = 5 CPH
High Efficiency Gas Forced Air = 3 CPH
Oil Forced Air = 5 CPH
Electric Forced Air = 9 CPH
Hot Water Fan Coil = 3 CPH
Hot Water Radiant Heat = 3 CPH
Geothermal Radiant Heat = 3 CPH
Steam = 1 CPH
Gravity = 1 CPH
Old 01-01-20, 08:38 AM
Received 4,059 Upvotes on 3,642 Posts
My opinion......
Pro.... more cycles per hour allow for a more constant overall temperature.
Con... more cycle per hour is harder on the equipment.
Old 01-01-20, 08:48 AM
JOB
JOB is offline
Thanks Houston for the response, when in doubt stick to the owner manual.
Thanks PJ for the input well said
JOB
Old 01-01-20, 08:57 AM
lawrosa's Avatar
Super Moderator
Received 85 Upvotes on 77 Posts
Usually at 50% load you will rarely see the CPH come into play IMO. I have heat pump and have mine set for 2. Why they would recommend 9 is beyond me..
I want long run times
But temperature will always over ride CPH
Old 01-01-20, 06:05 PM
JOB
JOB is offline
Thanks Larosa I have a new Honeywell after 23 years
The stat still reads the same temperature as the old one and the CPH was set the same as the old unit.
My run times are longer and my 2nd floor is now warmer then it ever was for the past 23 years.
Go figure!
JOB
