Replace T451a 24v thermostat with programmable
Old 01-03-20, 12:20 PM
I have 2 Honeywell T451a thermostats connected to a two wire 24v system. One for each of two zones. A black wire and a white wire. I checked with a multimeter and it is around 27 to 28 volts. It is an oil burner - hot water system with baseboard radiators. I would like to replace with programmable thermostats. Any ideas on what would work?
Old 01-03-20, 06:07 PM
Houston204's Avatar
Received 95 Upvotes on 88 Posts
Just about any thermostat that runs on batteries will work.
A Honeywell TH6110D1005 runs about $48 and will work.
A Honeywell touch screen TH8110R1008 runs about $133 and will support your equipment.
